Problema con URLs amigables
Inicio Foros General Joomla en General Problema con URLs amigables
  • Este debate tiene 5 respuestas, 2 mensajes y ha sido actualizado por última vez el hace 14 años, 7 meses por Anónimo.
    • #104009
      Hola!
      Tengo una copia de nuestra página en un servidor local (debian).
      Quiero utilizar las URL amigables, y en la configuración global las tengo activadas. No se que he de configurar, ya que no me funcionan:
      Not Found
      The requested URL *** was not found on this server.
      Apache/2.2.16 (Debian) Server at **** Port 80
      Os pego el .htaccess:
      # @version $Id: htaccess.txt 14401 2010-01-26 14:10:00Z louis $
      # @package Joomla
      # @copyright Copyright (C) 2005 – 2010 Open Source Matters. All rights reserved.
      # @license http://www.gnu.org/copyleft/gpl.html GNU/GPL
      # Joomla! is Free Software
      # READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE
      # The line just below this section: ‘Options +FollowSymLinks’ may cause problems
      # with some server configurations. It is required for use of mod_rewrite, but may already
      # be set by your server administrator in a way that dissallows changing it in
      # your .htaccess file. If using it causes your server to error out, comment it out (add # to
      # beginning of line), reload your site in your browser and test your sef url’s. If they work,
      # it has been set by your server administrator and you do not need it set here.
      ## Can be commented out if causes errors, see notes above.
      # mod_rewrite in use
      RewriteEngine On
      ########## Begin – Rewrite rules to block out some common exploits
      ## If you experience problems on your site block out the operations listed below
      ## This attempts to block the most common type of exploit `attempts` to Joomla!
      ## Deny access to extension xml files (uncomment out to activate)
      #Order allow,deny
      #Deny from all
      #Satisfy all
      ## End of deny access to extension xml files
      RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|%3D) [OR]
      # Block out any script trying to base64_encode crap to send via URL
      RewriteCond %{QUERY_STRING} base64_encode.*(.*) [OR]
      # Block out any script that includes a
      Podríais ayudarme?
    • #104010
    • #104014
      Gracias por contestar redlo.
      El archivo no es htaccess.txt. Ya está como .htaccess.
      Que podría ser?
    • #104041
      Alguien me podría ayudar?
    • #104044
      Si es una copia de un joomla, al trasladarlo ¿Has cambiado las rutas absolutas del archivo configuration.php?
    • #104047
      Si te refieres a las relativas de “logs” y “temps”, sí. Están cambiadas.
      Alguna otra idea?
